  • Wattgate 330 AU evo Clear Audio Grade Gold Plated Edison Power Connector
CLEARANCE Wattgate 330 AU evo Clear Audio Grade Gold Plated Edison Power Connector
WattgatePart # 110-462
Model: 330 AU EVO CLEAR/SMOKE
Wattgate's 330 AU evo Audio Grade Power Connector is the answer for those seeking the perfect power performance. If you desire pure loss-less power for your top of the line audio equipment, the 330 AU evo fits the bill.
  • Gold plated audio grade AC power connector
  • Accepts 8 to 14 AWG wire
  • Use cable with a diameter up to 19 mm
  • WattLock terminals for heavy duty wire capture
  • Polycarbonate design with all non-magnetic materials
  • High spring rate brass contacts
  • 2.5 mm hex socket hardware holds individual wires tightly
CLEARANCE $68.77
MSRP: $175.99
Save $107.22 (61%)
1 In Stock
We'll send you an email when Wattgate 330 AU evo Clear Audio Grade Gold Plated Edison Power Connector is back in stock or available for preorder.
Create the perfect power connection with the Wattgate 330 AU evo connector. These top of the line connectors are audio grade for several reasons. The three layer plating process starts with oxygen free copper, followed by electroless nickel plating, and finally 24k gold plating for improved conductivity.
The WattLock terminals lock in wire gauges from 8 to 14 so you can be confident that heat or vibrations will not dislodge your connections. This connector accepts cable diameters up to 19 mm. The Cryo treatment Wattgate employs means you get maximum AC transfer for premium sonic benefits to both audio and video equipment.
The construction of the connector body is all polycarbonate and uses all non-magnetic materials to reduce interference. These plugs are rated 125 VAC, 15 amp. Housing dimensions: 2.1" L x 1.5" D. Overall dimensions: 2.9" L x 1.5" D.
BrandWattgate
Model330 AU EVO CLEAR/SMOKE
Part Number110-462
UPC601431104628
Weight0.1
ConfigurationNEMA 5-15 Edison
Current Rating15A
Power Connector TypeCable Mount
