  • Warm White 3 LED Axial 8 VDC Replacement Lamp 5-Pack
CLEARANCE Warm White 3 LED Axial 8 VDC Replacement Lamp 5-Pack
Parts ExpressPart # 070-144
Rejuvenate your vintage stereo receivers without worrying that you will be replacing the lamps again. These three LED lamp boards provide a warm white glow for tuner dials, VU meters, and other types of level meters so your vintage equipment will come back to life.
  • Popular in vintage stereo equipment from the 70s and 80s
  • Draws less than 11 mA and runs cooler compared to incandescent bulbs
  • Pigtail leads for PC board applications
  • 5V to 12V AC or DC working voltage for versatility
  • Economical 5-pack
CLEARANCE $5.89
MSRP: $10.99
Save $5.10 (46%)
100 In Stock
We'll send you an email when Warm White 3 LED Axial 8 VDC Replacement Lamp 5-Pack is back in stock or available for preorder.
Stereo receivers and other audio equipment in the 70s and 80s use incandescent lamps to light up all types of displays. Large VU meter bulbs had to be soldered in because there was no room for fuse type lamp bulbs. That's why these three LED axial light boards are in many new and older products. They are able to solder into small, flat areas and still offer soft, wide illumination.
These LED axial lamps have multiple application possibilities, because they can work with 8 volt AC or DC. For 12 volt use, add a 100 ohm 1/2 watt resistor and now you have lighting for inside your vehicle. With a 9 volt AC adapter you can add lighting to large scale models or doll houses. Light up panels on small projects with at least 5V AC or DC. How will you use these long lasting LED axial lights?
Specification: • Color: Warm white • Dimensions: 0.99" L x 0.23" W x 0.11" H (25 x 6 x 2.86 mm) without leads and at the highest point • 8 VAC or 8 VDC • Current draw: 23 mA.
Part Number070-144
UPC848864052007
Unit of MeasurePackages
