WONDOM AA-AB31242 1x600W Class D Audio Amplifier Board (T-Amp Technology)This mid power mono amplifier board means serious business! This audio amplifier board cranks out 600 watts of power using WONDOM T-AMP technology, featuring low distortion and low noise level. For do-it-yourselfers, looking for a subwoofer amp for your home or vehicle.
A robust heatsink, two-stage cooling fan, as well as protection circuits to protect against over/under voltage, over current, short circuit, and over temperature conditions are built-in for years of enjoyment. Three fixed gain settings allow you to match the amplifier to your source, and use your source as the volume control or Sure's plug in volume control option. A 24 to 40 VDC power supply is required.
Note: The minimum recommended wire gauge to be used for power is 16 AWG.
• Power output (w/ 36 VDC power supply): 600W x 1 (1.5 ohms, THD 10%), 393W x 1 (1.5 ohms, THD 1%)
• Minimum impedance: 1.5 ohms
• Frequency response: 20 to 20,000 Hz (±3 dB)
• SNR: 93 dB (393W @ 1.5 ohms THD+N 1%)
• Recommended power supply: 24 to 40 VDC, 16.3A regulated
• Fixed gain settings: 28 dB, 30 dB, 32 dB
• Power input jack: 2.5 x 5.5 mm, center-positive
• Dimensions without RCA jack: 6" L x 4.5" W x 1.53" H
