  • Visaton WS25 E 10" Paper Cone Woofer 8 Ohm
VisatonPart # 292-598
Model: WS25
Replace tired, worn 10" woofers in your classic, vintage speakers with the Visaton WS25 E. The rubber surround will never deteriorate, and the bumped backplate protects it from damage.
  • High Qts design for sealed cabinets
  • Rubber surround won't disintegrate
  • Bumped backplate and 5.5 mm of Xmax
Your Price: $53.47
MSRP: $56.99
Save $3.52 (6%)
We'll send you an email when Visaton WS25 E 10" Paper Cone Woofer 8 Ohm is back in stock or available for preorder.
Order in the next 13 hr 26 min to ship today. Details
Visaton designed the WS25 E 10" 8 ohm woofer to replace vintage and modern home audio hi-fi woofers in sealed cabinet speakers.
For a classic natural sound, the WS25 E features a coated paper cone. A rubber surround and bumped back plate protect this woofer from overexcursion. Both the low free-air resonance and low inductance allow this driver to play from 34 Hz up to 6,000 Hz, making great for use in small 3-way speakers as well as large format 2-way speakers.
BrandVisaton
ModelWS25
Part Number292-598
Weight2.76
Nominal Diameter10"
Bolt Circle Diameter10.31
Power Handling (RMS)80 Watts
Power Handling (MAX)110 Watts
Frequency Response34 to 6,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)34Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.8mH
Mechanical Q (Qms)2.82
Electromagnetic Q (Qes)2.92
Total Q (Qts)1.43
Compliance Equivalent Volume (Vas)3.99ft³
BL Product (BL)3.8T·m
Diaphragm Mass Inc. Airload (Mms)33g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)346cm²
Cone MaterialTreated Paper
Overall Outside Diameter11.14" across the mounting tabs, 9.65"
Baffle Cutout Diameter8.82"
Depth4.17"
Sealed Volume1.75ft³
Sealed F341.8Hz
