  • Visaton W250S-8 10" Woofer with Treated Paper Cone 8 Ohm
VisatonPart # 292-576
Model: W250S - 8
The 9035 W250S 10" woofer from Visaton delivers amazing performance not normally found in drivers this size at this price point. A low Qts allows you to get very deep bass in a reasonably sized ported enclosure.
  • Very flat frequency response for easy system integration
  • Great for use as a HiFi woofer or as a subwoofer
  • Great sensitivity combined with low Fs and Qts for high performance
Your Price: $115.18
MSRP: $131.99
Save $16.81 (13%)
Only 4 In Stock
We'll send you an email when Visaton W250S-8 10" Woofer with Treated Paper Cone 8 Ohm is back in stock or available for preorder.
Order in the next 3 hr 43 min to ship today. Details
Visaton's 9035 W250S 10" woofer features a coated paper cone, durable rubber surround, and a bumped back plate to allow all 5 mm of Xmax to be used with an excursion limit of ±7 mm. A balanced design approach between sensitivity, smooth frequency response (cross it over as high as 2,500 Hz), and extended bass allows this driver to be used as a high-output HiFi woofer in three-way speaker systems or as a subwoofer.
Note: For best bass performance, install the W250S into one of the following cabinets:
• A 1.77 cubic foot cabinet tuned to 43 Hz with two 2-1/2" diameter ports that are 5-3/4" long.
• A 2.47 cubic foot cabinet tuned to 39 Hz with two 2-1/2" diameter ports that are 5-3/4" long.
• A 3.53 cubic foot cabinet tuned to 34 Hz with two 2-1/2" diameter ports that are 3-15/16" long.
BrandVisaton
ModelW250S - 8
Part Number292-576
Weight7.716
Nominal Diameter10"
Power Handling (RMS)100 Watts
Power Handling (MAX)150 Watts
Frequency Response31 to 5,500Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)31Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)1.5mH
Mechanical Q (Qms)1.88
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.32
Compliance Equivalent Volume (Vas)4.27ft³
Cone MaterialTreated Paper
Overall Outside Diameter11.14"
Baffle Cutout Diameter9.2"
Depth4.41"
Sealed Volume0.9ft³
Sealed F376.7Hz
Vented Volume1.8ft³
Vented F342.4Hz
