  • Visaton SL87XA-4 3-1/4" Waterproof Poly Cone Full-Range Driver 4 Ohm
VisatonPart # 292-708
Model: SL87XA-4
The Visaton SL87XA-4 is a waterproof 3.3" full-range speaker with a transparent plastic cone, optimised for voice and signal output with a very high mean sound pressure level.
  • Rated power of 20W and maximum power of 30W
  • Frequency response of 350–5800 Hz
  • Wide temperature range from -40 to 70°C
  • UV and weather-resistant, ideal for outdoor applications
  • Waterproof full-range speaker with IP65 protection
Your Price: $14.28
MSRP: $14.99
Save $0.71 (5%)
Quantity:Qty: 1-9 $14.28/ea
Quantity:Qty: 10+ $13.13/ea
8 In Stock
We'll send you an email when Visaton SL87XA-4 3-1/4" Waterproof Poly Cone Full-Range Driver 4 Ohm is back in stock or available for preorder.
The Visaton SL87XA-4 is a robust 3.3" full-range speaker that delivers superior sound performance even in challenging outdoor conditions. This speaker is waterproof, with an IP65 rating, and features a transparent plastic cone along with a rubber sealing ring. Designed for a high auditory experience, the SL87XA-4 is optimised for voice and signal output and achieves a very high mean sound pressure level of 94 dB. Its power range between 20W and 30W, along with a frequency response of 350–5800 Hz, ensures a clear and comprehensive sound output. The speaker is UV and weather-resistant, making it a perfect choice for outdoor sound reinforcement systems and alarm systems. With a resilient temperature range from -40 to 70°C, it is capable of functioning efficiently in various environments. Installation is also made easy with a cutout diameter of 80 mm.
BrandVisaton
ModelSL87XA-4
Part Number292-708
Weight0.85
Nominal Diameter3"
Power Handling (RMS)20 Watts
Power Handling (MAX)30 Watts
Frequency Response350 to 5,800Hz
Sensitivity94dB 2.83V/1m
Voice Coil Diameter0.79"
Resonant Frequency (Fs)550Hz
Cone MaterialPoly
Overall Outside Diameter3.27"
Baffle Cutout Diameter3.15"
Depth1.46"
