  • Visaton ML10T 4" Ceiling/Wall Speaker 100V White
CLEARANCE Visaton ML10T 4" Ceiling/Wall Speaker 100V White
VisatonPart # 292-652
Model: ML10T
Choose Visaton's ML 10 T-100V 4" ceiling speaker for background music on your 100 volt distributed audio system. The quick-release terminal block makes connection easy and the rear chamber provides protection from debris.
  • One-piece paintable grill for a clean look
  • Fully enclosed rear chamber protects driver and transformer
  • Screw mount allows installation in difficult locations
  • Includes 100V transformer with 6, 3, and 1.5 watt power taps
CLEARANCE $15.00
MSRP: $54.08
Save $39.08 (72%)
6 In Stock
We'll send you an email when Visaton ML10T 4" Ceiling/Wall Speaker 100V White is back in stock or available for preorder.
Visaton's ML 10 T-100V 4" ceiling speaker is built for easy installation and connection to 100 volt commercial audio systems. A built-in 100 volt transformer, with taps for 6, 3, and 1.5 watt settings, is connected to a push-terminal block for easy level adjustments. A sealed rear chamber provides protection for the rear of the driver against insulation and moisture while ensuring consistent sound in different installation situations. This compact ceiling speaker excels in the vocal range, making it ideal for use in paging systems.
Specifications: • Tap settings: 1.5, 3, 6 watts • VCdia: 20 mm • Le: 0.50 mH • Frequency response: 150-15,000 Hz • SPL: 85 dB 1W/1m • Max SPL: 92 dB 6W/1m • Dimensions: Overall diameter: 5.11", Cutout diameter: 4", Depth: 3.36".
BrandVisaton
ModelML10T
Part Number292-652
Weight2.3
Input Rating100V
Mounting StyleIn-ceiling
Woofer Diameter4"
Special FeaturesEnclosed Back-Weather Resistant
