  • Visaton K64WP-8 2.5" Full-Range Water Resistant Speaker 8 Ohm
VisatonPart # 292-534
Model: K64WP - 8
Choose the 2918 K64WP 2.5" full-range speaker from Visaton for outdoor applications where direct moisture and high humidity are a factor.
  • IP65 rated speaker for outdoor use
  • UL 94-rated ABS basket
  • One-piece mylar cone and surround
  • Designed for vocal reproduction
Your Price: $8.83
MSRP: $9.99
Save $1.16 (12%)
72 In Stock
We'll send you an email when Visaton K64WP-8 2.5" Full-Range Water Resistant Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 1 hr 6 min to ship today. Details
Visaton's 2918 K64WP 2-1/2" full-range speaker features a unique weather and UV-resistant design. A UL 94-rated ABS basket is used in conjunction with a one-piece mylar cone and surround. This allows the K64WP to be used in outdoor audio applications where water and high humidity are a factor. When used in a sealed enclosure, the front of this speaker conforms to the IP65 water resistance rating (meaning it can withstand direct moisture). The K64WP's specialty is vocal reproduction with great output in the 300 to 1,500 Hz range, making this the perfect outdoor PA speaker for announcements.
Note: For maximum power handling, a 1st-order 300 Hz high-pass filter is recommended.
BrandVisaton
ModelK64WP - 8
Part Number292-534
Weight0.137
Nominal Diameter2-1/2"
Power Handling (RMS)2 Watts
Power Handling (MAX)3 Watts
Frequency Response200 to 15,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter0.39"
Resonant Frequency (Fs)300Hz
Maximum Linear Excursion (Xmax)0.25mm
Cone MaterialPoly / Mylar Diaphragm
Overall Outside Diameter2.52"
Baffle Cutout Diameter2.36"
Depth0.64"
