  • Visaton K36WP 1.4" Miniature Speaker 8 Ohm
CLEARANCE Visaton K36WP 1.4" Miniature Speaker 8 Ohm
VisatonPart # 292-623
Model: K36WP
The Visaton K 36 WP is a versatile, IP65-rated 1.4" mini speaker with a black Mylar diaphragm and an 8 ohm impedance. Great for small device applications where vocal reproduction is needed or as a replacement speaker in headphones.
  • Particularly well suited for outdoor applications
  • 1.25" mylar diaphragm produces wide frequency response
  • Excellent off axis response throughout the usable bandwidth
  • IP-65 rated for use in harsh conditions
We'll send you an email when Visaton K36WP 1.4" Miniature Speaker 8 Ohm is back in stock or available for preorder.
Featuring a smooth-sounding 1-1/4" Mylar diaphragm and 8 ohm impedance, Visaton's K 36 WP weatherproof driver is the perfect for low-power mini speaker applications, such as electronic toys, speakerphones, and intercoms, where risk of contact with moisture is high.
Note: The Mylar diaphragm is very fragile. To prevent damage, avoid contact with the diaphragm when handling. This driver should be installed behind a grille.
BrandVisaton
ModelK36WP
Part Number292-623
Nominal Diameter1"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response300 to 20,000Hz
Sensitivity77dB 2.83V/1m
Voice Coil Diameter0.4"
Resonant Frequency (Fs)550Hz
Maximum Linear Excursion (Xmax)0.5mm
Cone MaterialPoly / Mylar Dome
Magnet MaterialNeodymium
Overall Outside Diameter1.41"
Baffle Cutout Diameter1.22"
Depth0.23"
