  • Visaton K 28 WP 1.1" Miniature Speaker 8 Ohm
VisatonPart # 292-618
Model: K 28
The Visaton K 28 WP is a versatile, IP65-rated mini speaker with a black Mylar diaphragm and an 8 ohm impedance. Great for small device applications where vocal reproduction is needed.
  • IP65-rated for resistance to moisture
  • 1" mylar diaphragm
  • Great frequency response from 500 to 20,000 Hz
Your Price: $5.57
MSRP: $5.99
Save $0.42 (7%)
751 In Stock
We'll send you an email when Visaton K 28 WP 1.1" Miniature Speaker 8 Ohm is back in stock or available for preorder.
Featuring a smooth-sounding 1" Mylar diaphragm and 8 impedance, Visaton's K 28 WP weatherproof driver is the perfect for low-power mini speaker applications, such as electronic toys, speakerphones, and intercoms, where risk of contact with moisture is high.
Note: The Mylar diaphragm is very fragile. To prevent damage, avoid contact with the diaphragm when handling. This driver should be installed behind a grille.
BrandVisaton
ModelK 28
Part Number292-618
Weight0.02
Nominal Diameter1"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response300 to 20,000Hz
Sensitivity75dB 2.83V/1m
Voice Coil Diameter0.39"
Resonant Frequency (Fs)700Hz
Maximum Linear Excursion (Xmax)0.5mm
Cone MaterialPoly / Mylar Diaphragm
Overall Outside Diameter1.10"
Baffle Cutout Diameter0.83"
Depth0.22"
