  • Visaton K28GI8 1.1" Miniature Speaker 8 Ohm
CLEARANCE Visaton K28GI8 1.1" Miniature Speaker 8 Ohm
VisatonPart # 292-7829
Model: K 28 GI
The Visaton K28GI8 is a 2.8 cm (1.1") miniature speaker engineered for applications requiring compact and efficient audio solutions. Its polycarbonate membrane and round plastic basket ensure durability and consistent performance, making it ideal for signal output in space-constrained devices. With robust construction and spring contacts for easy installation, this speaker is a reliable choice for industrial and outdoor applications.
  • Frequency response from 500 Hz to 7,000 Hz for clear and intelligible audio
  • Resonance frequency at 730 Hz for clarity in voice and signal outputs
  • Rated power handling of 0.5 W for energy-efficient operation in low-power devices
  • IP65 and IP68 protection ratings for resistance to dust and water ingress
CLEARANCE $6.00
MSRP: $10.97
Save $4.97 (45%)
23 In Stock
We'll send you an email when Visaton K28GI8 1.1" Miniature Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 5 hr 21 min to ship today. Details
The K28GI8 Ohm delivers excellent performance in a durable and compact design. Its wide frequency response and high protection ratings make it suitable for industrial and outdoor devices. Whether integrated into equipment or used in signal systems, this speaker ensures consistent and reliable audio output.
*) IP 65 protection class for front side when built into a sealed enclosure.
**) IP 68 protection class at 1 m height of water, 48 h
Technical Data
  • Rated power: 0.5 W
  • Maximum power: 1 W
  • Nominal impedance Z: 8 Ohm
  • Frequency response: 500–7000 Hz
  • Mean sound pressure level: 84 dB (1 W/1 m)
  • Resonance frequency fs: 730 Hz
  • Net weight: 0.006 kg
  • Connections: spring contacts
  • Protective system: IP 65 *) IP 68 *) **)
  • Temperature range: −40 - 85 °C
BrandVisaton
ModelK 28 GI
Part Number292-7829
Weight0.01
Nominal Diameter1-1/10"
Power Handling (RMS)0.5 Watts
Power Handling (MAX)1 Watts
Frequency Response500 to 7000Hz
Sensitivity84dB 2.83V/1m
Resonant Frequency (Fs)730Hz
# Mounting Holes2
