  • Visaton FRS8M 3.3" Paper Cone Full-Range Driver 8 Ohm
VisatonPart # 292-692
Model: FRS8M
The Visaton FRS8M is an 8 ohm 8 cm (3.3") full-range speaker offering high force factor and excellent sensitivity. It's specially designed for use in column speakers and small bass-reflex cabinets, such as in mini subwoofer/satellite systems.
  • Full-range 3.3" speaker with high force factor and good sensitivity
  • Specially developed for use in column speakers and small bass-reflex cabinets
  • Ideal for miniature subwoofer/satellite systems
  • Moisture-resistant membrane for enhanced durability
  • Durable metal design
Your Price: $18.35
1 In Stock
We'll send you an email when Visaton FRS8M 3.3" Paper Cone Full-Range Driver 8 Ohm is back in stock or available for preorder.
Order in the next 14 hr 2 min to ship today. Details
Choose the FRS8M 3.3" full-range speaker from Visaton for a superior audio experience in a variety of applications. This driver is perfect for use in column speakers and mini HiFi systems, and excels in small bass-reflex cabinets, such as in miniature subwoofer/satellite systems. The FRS8M comes with a high force factor and excellent sensitivity, ensuring a powerful and accurate sound experience. It features a moisture-resistant membrane, offering enhanced durability and longevity even in challenging conditions. The durable metal design adds to its robustness, making the FRS8M a reliable choice for your audio needs.
BrandVisaton
ModelFRS8M
Part Number292-692
Weight1.1
Nominal Diameter3"
Power Handling (RMS)30 Watts
Power Handling (MAX)50 Watts
Frequency Response100 to 20,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter0.79"
Resonant Frequency (Fs)125Hz
DC Resistance (Re)7.2Ω
Mechanical Q (Qms)3.24
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.49
Compliance Equivalent Volume (Vas)0.388ft³
Mechanical Compliance of Suspension (Cms)0.921mm/N
BL Product (BL)4T·m
Diaphragm Mass Inc. Airload (Mms)1.8g
Surface Area of Cone (Sd)29cm²
Cone MaterialPaper
Overall Outside Diameter3.07"
Baffle Cutout Diameter2.95"
Depth1.85"
Sealed Volume0.0224ft³
Sealed F3200Hz
Vented Volume0.05ft³
Vented F3116Hz
