  • Visaton FRS7XWP8 2.5" Full-Range Speaker 8 Ohm
VisatonPart # 292-7812
Model: FRS 7 XWP
The Visaton FRS 7 XWP is a 6.5 cm (2.5") full-range speaker designed for high-quality audio reproduction in compact enclosures. Its balanced frequency response and excellent high-frequency performance make it suitable for built-in music systems and column speakers. Optimized for small closed and bass-reflex enclosures, it delivers impressive audio quality, even in the bass range.
  • Frequency response up to 20,000 Hz
  • Resonance frequency at 100 Hz
  • Excursion limit of ±5.0 mm
  • Effective piston area of 23.6 cm²
  • IP64-rated protection against dust and splashing water
  • Operating temperature range from −40 to 85 °C
Your Price: $21.63
We'll send you an email when Visaton FRS7XWP8 2.5" Full-Range Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 7 hr 4 min to ship today. Details
The FRS 7 XWP's design includes a waterproof membrane and metal construction, ensuring durability and reliable performance in various environmental conditions. Its compact size and high power reserves make it an excellent choice for applications requiring quality sound reproduction in limited spaces. Additionally, it is compatible with the Grille FRS 7 (Art. No. 2312) for added protection and aesthetic integration.
Technical Data
  • Cm: 1.08 mm/N
  • Rated power: 10 W
  • Nominal impedance Z: 8 Ohm
  • Frequency response: fu–20000 Hz
    (fu: Lower cut-off frequency depending on cabinet)
  • Mean sound pressure level: 81 dB (1 W/1 m)
  • Excursion limit: ±5.0 mm
  • Resonance frequency fs: 100 Hz
  • Magnetic induction: 1.0 T
  • Height of front pole-plate: 3 mm
  • Voice coil diameter: 20.38 mm
  • Height of winding: 8.8 mm
  • Net weight: 0.360 kg
  • Mechanical Q factor Qms: 3.55
  • Electrical Q factor Qes: 0.74
  • Total Q factor Qts: 0.62
  • Equivalent Volume Vas: 0.85 l
  • Effective piston area Sd: 23.6 cm²
  • Dynamically moved mass Mms: 2.5 g
  • Force factor Bxl: 3.60 Tm
  • Inductance of the voice coil L: 0.53 mH
  • Connections: 2.8 x 0.5/2.8 x 0.5 mm
  • Protective system: IP 64 *)
  • Temperature range: −40 to 85°C
BrandVisaton
ModelFRS 7 XWP
Part Number292-7812
Weight0.79
Nominal Diameter2-1/2"
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Sensitivity81dB 2.83V/1m
Voice Coil Diameter0.8"
Resonant Frequency (Fs)100Hz
Voice Coil Inductance (Le)0.53mH
Mechanical Q (Qms)3.55
Electromagnetic Q (Qes)0.74
Total Q (Qts)0.62
Compliance Equivalent Volume (Vas)0.03ft³
BL Product (BL)3.6T·m
Diaphragm Mass Inc. Airload (Mms)2.5g
Surface Area of Cone (Sd)23.6cm²
