  • Visaton FRS7A8 2.5" Full-Range Speaker 8 Ohm
VisatonPart # 292-7827
Model: FRS 7 A
Read 1 Review or
The Visaton FRS7A8 is a 6.5 cm (2.5") full-range speaker designed for applications requiring balanced frequency response and high efficiency in a compact form factor. Its waterproof membrane and metal construction make it suitable for environments where durability and moisture resistance are essential. This speaker is ideal for use in narrow network column speakers, electronic musical instruments, and as a monitoring speaker for electronic devices.
  • Balanced frequency response from 200 Hz to 20,000 Hz
  • Waterproof membrane for durability in moist environments
  • Metal construction resistant to temperatures from -25 up to 100 °C
  • Compact size suitable for integration into narrow enclosures
Your Price: $15.19
Quantity:Qty: 1-9 $15.19/ea
Quantity:Qty: 10+ $13.67/ea
We'll send you an email when Visaton FRS7A8 2.5" Full-Range Speaker 8 Ohm is back in stock or available for preorder.
The FRS7A8 combination of balanced sound reproduction, high efficiency, and robust design makes it an excellent choice for various audio applications, including model construction and electronic musical instruments. Its compact size allows for easy integration into limited spaces, while the waterproof membrane ensures reliability in challenging conditions.
Technical Data
  • Rated power: 8 W
  • Maximum power: 15 W
  • Nominal impedance Z: 8 Ohm
  • Frequency response: 200–20000 Hz
  • Mean sound pressure level: 88 dB (1 W/1 m)
  • Opening angle (-6 dB): 149°/4000 Hz
  • Resonance frequency fs: 220 Hz
  • Voice coil diameter: 14 mm
  • Net weight: 0.2 kg
  • Connections: 2.8 x 0.8 mm (+)/2.8 x 0.8 mm (-)
  • Temperature range: −25 - 100 °C
BrandVisaton
ModelFRS 7 A
Part Number292-7827
Weight0.44
Nominal Diameter2-1/2"
Power Handling (RMS)8 Watts
Power Handling (MAX)15 Watts
Frequency Response200 to 20000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter0.55"
Resonant Frequency (Fs)220Hz
