  • Visaton Electro Dynamical Exciter 10W 8 Ohm EX45S-8
CLEARANCE Visaton Electro Dynamical Exciter 10W 8 Ohm EX45S-8
VisatonPart # 292-730
Model: EX45S-8
The Visaton EX45S-8 is an electro-dynamical exciter, designed to stimulate bending waves on plates. This unit provides a unique alternative to traditional speakers, offering the ability to generate sound in applications where normal speakers aren't an option due to aesthetic or environmental considerations.
  • Maximum power of 10W
  • Electro-dynamical exciter that stimulates bending waves on plates
  • Ideal for applications where conventional speakers aren't suitable
  • Can operate within a temperature range of -25 °C to +70 °C
  • Can be attached to the surface of the plate by gluing or screwing
CLEARANCE $22.50
MSRP: $42.91
Save $20.41 (48%)
10 In Stock
We'll send you an email when Visaton Electro Dynamical Exciter 10W 8 Ohm EX45S-8 is back in stock or available for preorder.
Order in the next 3 hr 26 min to ship today. Details
The Visaton EX45S-8 is an electro-dynamical exciter, specifically designed to stimulate bending waves on plates for its output. Unlike conventional speakers, this unit can generate sound in a variety of situations where traditional speakers may not be suitable, such as in visually sensitive settings, or areas requiring protection against environmental conditions or vandalism. The EX45S-8 can be attached to the surface of the plate, either by gluing or screwing, allowing for a degree of flexibility in its installation. With a voice coil diameter of 25.4 mm and a maximum power of 10W, this exciter is capable of producing significant acoustic energy. The device can operate within a temperature range of -25 °C to +70 °C, making it suitable for various environmental conditions. Connections are made via 4.8 x 0.8 mm (+) and 2.8 x 0.8 mm (-) terminals. The Visaton EX45S-8 offers a distinct, versatile, and robust solution for sound generation in a variety of challenging applications.
BrandVisaton
ModelEX45S-8
Part Number292-730
Weight0.15
Power Handling (RMS)10 Watts
