  • Visaton DL8-100V 3.3" Ceiling Mounted Speaker
VisatonPart # 292-646
Model: DL8-100V
Visaton's DL 8-100V 3.3" ceiling speaker is a compact solution for home and professional use with impressive sound quality. Thanks to spring loaded terminals and mounting arms installation is as easy as can be.
  • Moisture resistant cone for use in damp locations
  • Compact size for a clean installation
  • Ideal for use in all hollow ceilings
Your Price: $51.60
MSRP: $54.99
Save $3.39 (6%)
Out of Stock
We'll send you an email when Visaton DL8-100V 3.3" Ceiling Mounted Speaker is back in stock or available for preorder.
Special Order Items ships in 40-60 days
The DL 8-100V 3.3" ceiling-mounted speaker is ideal for adding music to any commercial or industrial environment. For easy installation in 3.25" round cutouts, this speaker uses spring loaded arms and wire terminals. This speaker provides compact solution for home and professional use where small size is the main concern.
Specifications: • Power handling: 5 watts RMS/10 watts max • 100V tap settings: 0.75W, 1.5W, 3W • Frequency response: 90-18,000 Hz • SPL: 90 dB 1W/1m • Dimensions: 4.13" dia. x 2.9" D • Cutout size: 3.25" dia. • Sold individually.
BrandVisaton
ModelDL8-100V
Part Number292-646
Weight1.25
Input Rating100V
Mounting StyleIn-ceiling
Woofer Diameter4"
Special FeaturesWeather Resistant
