  • Visaton BG13P 5" Full Range Speaker 8 Ohm
VisatonPart # 292-644
Model: BG13P
Visaton's BG 13 P 5" full-range speaker has a wide frequency response and excels at voice reproduction. The use of a whizzer cone improves high frequency response.
  • High efficiency for a compact driver
  • Ideal for use in vocal reproduction
  • Whizzer cone improves high frequency response
  • Smooth response from 150 to 20,000 Hz
Your Price: $21.20
Save $1.79 (8%)
11 In Stock
We'll send you an email when Visaton BG13P 5" Full Range Speaker 8 Ohm is back in stock or available for preorder.
The BG 13 P 5" dual cone full-range delivers high efficiency across an extremely wide frequency range for a driver this size. Optimized for reproducing the human voice, this speaker is perfect for use in large scale PA line arrays or even small monitor speakers.
BrandVisaton
ModelBG13P
Part Number292-644
UPC4007540030111
Weight1.05
Nominal Diameter5"
Bolt Circle Diameter4.75
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Impedance8Ω
Frequency Response120 to 20,000Hz
Sensitivity92dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)168Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.65mH
Mechanical Q (Qms)3.06
Electromagnetic Q (Qes)1.58
Total Q (Qts)1.042
Compliance Equivalent Volume (Vas)2.01ft³
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)3.22T·m
Diaphragm Mass Inc. Airload (Mms)3g
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter5.15"
Baffle Cutout Diameter4.33"
Depth1.81"
Sealed Volume0.5ft³
Sealed F3257.9Hz
