  • Visaton BF 32 S WP 1.3" Fullrange Speaker 8 Ohm
NEW Visaton BF 32 S WP 1.3" Fullrange Speaker 8 Ohm
VisatonPart # 292-503
Model: BF 32 S WP - 8 Ohm
The Visaton BF 32 S WP – 8 Ohm is a compact 3.2 cm (1.3″) full-range speaker designed for wide and balanced audio reproduction with good low-end response. Its water-resistant construction and neodymium drive make it suitable for compact audio devices and installations in environments where moisture may be present.
  • Compact 1.3″ full-range speaker with wide, balanced frequency response from ~145 Hz to 20 kHz
  • Powerful neodymium magnet motor for efficient sound generation
  • Black aluminum diaphragm with rubber surround for water-resistant operation
  • Square basket with four mounting holes for simple installation
  • Designed for humid environments and compact audio applications like flat TVs or info terminals
NEW $21.98
We'll send you an email when Visaton BF 32 S WP 1.3" Fullrange Speaker 8 Ohm is back in stock or available for preorder.
BrandVisaton
ModelBF 32 S WP - 8 Ohm
Part Number292-503
Nominal Diameter1"
Power Handling (RMS)2 Watts
Frequency Response145 to 20,000Hz
Sensitivity88dB 2.83V/1m
Resonant Frequency (Fs)280Hz
Maximum Linear Excursion (Xmax)0.6mm
Magnet MaterialNeodymium
Overall Outside Diameter1.26"
Baffle Cutout Diameter1.14"
Depth0.41"
