  • Visaton BF 30 R 1.2" Fullrange Speaker 4 Ohm
NEW Visaton BF 30 R 1.2" Fullrange Speaker 4 Ohm
VisatonPart # 292-507
Model: BF 30 R - 4 Ohm
The Visaton BF 30 R – 4 Ohm is a compact 3 cm (1.2″) full-range loudspeaker driver designed for balanced music and speech reproduction in compact audio systems. Its neodymium drive and wide frequency response make it suitable for applications requiring slim construction without sacrificing sound quality.
  • Compact 1.2″ full-range speaker driver for small-format designs
  • Wide and balanced frequency response from about 240 Hz to 20 kHz
  • Neodymium driver motor for improved acoustic output
  • Solder lug connections for straightforward wiring
NEW $14.98
We'll send you an email when Visaton BF 30 R 1.2" Fullrange Speaker 4 Ohm is back in stock or available for preorder.
BrandVisaton
ModelBF 30 R - 4 Ohm
Part Number292-507
Weight0.5
Power Handling (RMS)2 Watts
Frequency Response240 to 20,000Hz
Sensitivity77dB 2.83V/1m
Resonant Frequency (Fs)380Hz
Magnet MaterialNeodymium
