  • Visaton 50133 ML 16A 6.5" Ceiling speaker
CLEARANCE Visaton 50133 ML 16A 6.5" Ceiling speaker
VisatonPart # 900-ML16A
Model: 50133
The Visaton ML 16 A - 100 V (NCS S 0500-N) is a 16 cm (6.5") ceiling speaker designed for high efficiency and clear speech reproduction, making it ideal for installation in metal ceilings, such as those on ships. Its robust construction and compliance with Germanischer Lloyd standards ensure reliable performance in demanding environments.
  • High efficiency and clear speech reproduction​
  • Suitable for installation in metal ceilings (e.g., ships)​
  • Push-terminal block for quick 100 V network connection​
  • Quick-mounting bayonet connection for easy grille installation​
  • Operational at low temperatures (-40 °C; 96 h) per EN 60068-2-1​
  • Moisture-resistant cone and UV-resistant materials​
CLEARANCE $19.80
Save $2.20 (10%)
7 In Stock
We'll send you an email when Visaton 50133 ML 16A 6.5" Ceiling speaker is back in stock or available for preorder.
Order in the next 8 hr 59 min to ship today. Details
The ML 16 A - 100 V (NCS S 0500-N) ceiling speaker is engineered for optimal performance in specialized applications, particularly where metal ceilings are present. Its high efficiency and excellent speech intelligibility make it a reliable choice for environments requiring clear audio transmission. The speaker's design facilitates straightforward installation: a push-terminal block allows for quick connection to 100 V networks with necessary level adjustments, and the quick-mounting bayonet connection simplifies grille attachment after securing the speaker to the ceiling. Built to withstand harsh conditions, this model operates effectively at low temperatures, meeting the EN 60068-2-1 standard (-40 °C; 96 h), and adheres to Germanischer Lloyd requirements for electrical equipment in low-temperature settings. Additionally, its moisture-resistant cone and UV-resistant materials ensure durability and longevity, even in challenging environments.
  • Nominal impedance (Z): 5; 10; 20 kOhm
  • Frequency response: 100–15000 Hz
  • Mean sound pressure level: 94 dB (1 W/1 m)
  • Opening angle (-6 dB): 54°/4000 Hz
  • Resonance frequency (fs): 150 Hz
  • Voice coil diameter: 14 mm
  • Cutout diameter: 143 mm
  • Net weight: 1.1 kg
  • Transformer matching: 2W/1 W/0.5 W
  • Max. sound pressure level: 97 dB (2 W/1 m)
  • Colour: NCS S 0500-N
  • Connections: Spring terminals
  • Protective system: IP 22
  • Temperature range: −40 ... 110 °C
BrandVisaton
Model50133
Part Number900-ML16A
Weight1.3
Input Rating100V
Mounting StyleIn-ceiling
Woofer Diameter6.5"
