Bring the focus to your flat panel TV while hiding the mount, or extend the mount up to 17" from the wall to fit every viewing need. This mount goes from hidden to extended with ease, extending 3" to 17" from the wall. The single-stud mount holds TVs from 37" to 75" and up to 100 pounds. The mount tilts 20 degrees down and 10 degrees up, while pivoting from left to right (range depends on the size of your TV). Installation is made easy with the integrated leveling system which helps alleviate any leveling issues when the mount is installed. UL tested.
Specifications: • Mounting bracket: 6-3/4" W x 14-1/6" H • Tilt: -20 to +10° • Minimum mount to wall distance: 3" • Maximum extended distance from wall: 17" • Supported VESA sizes: 200 x 200, 300 x 300, 400 x 200, 400 x 400, 600 x 200, and 600 x 400 • Maximum weight capacity: 100 lbs. • Must be single-stud mounted.
