The powder coated steel, articulating wall mount goes from hidden to extended with ease. The unit extends from 5" to 17" from the wall. The single stud mount holds 19" to 40" TVs (or larger depending on the VESA pattern of your TV) and weighing up to 80 pounds. The mount tilts 12 degrees up and down as well as pivots 180 degrees from left to right. Installation is made easy with the integrated leveling system which helps prevent any tilt or angle when the mount is installed. UL tested.
Specifications: • Mounting bracket: 6-3/4" W x 14-1/6" H • Tilt: ±12° • Minimum mount to wall distance: 5" • Maximum extended distance from wall: 17" • Supported VESA sizes: 75 x 75, 100 x 100, 200 x 100, 200 x 200, and 300 x 200 • Maximum weight capacity: 80 lbs. • Must be single-stud mounted.
