  • Ultimate Support 12373 Lighting Stand Hardware Kit (Bolts, Washers, Saddles)
NEW Ultimate Support 12373 Lighting Stand Hardware Kit (Bolts, Washers, Saddles)
Ultimate SupportPart # 242-7058
Model: 12373
Most Ultimate Support stands feature field-replaceable parts. In the unlikely event that a part on an Ultimate Support product breaks, you'll be able to simply replace the part affordably rather than replacing the entire stand. The 12373 Hardware Kit (Bolts, Washers, Saddles) is compatible with the LT-88B, LT-99B, LT99BL, LT-48FP, LTB-24B, and LTB-48FP.
NEW $12.50
We'll send you an email when Ultimate Support 12373 Lighting Stand Hardware Kit (Bolts, Washers, Saddles) is back in stock or available for preorder.
Most Ultimate Support stands feature field-replaceable parts. In the unlikely event that a part on an Ultimate Support product breaks, you'll be able to simply replace the part affordably rather than replacing the entire stand. The 12373 Hardware Kit (Bolts, Washers, Saddles) is compatible with the LT-88B, LT-99B, LT99BL, LT-48FP, LTB-24B and LTB-48FP.
BrandUltimate Support
Model12373
Part Number242-7058
UPC784887123730
Weight0.02
