  • USB Powered Magnifying 4" 3D + 12D Glass Lens Desk Lamp with Base, Clamp and Dual Color LED-White
CLEARANCE USB Powered Magnifying 4" 3D + 12D Glass Lens Desk Lamp with Base, Clamp and Dual Color LED-White
Parts ExpressPart # 350-026
This LED magnifier lamp is the perfect solution for technicians, crafters, and anyone else who needs a better look at fine detail. Use it on a desk or clamp it to a laptop to utilize the 18 warm or 18 cold white super bright LEDs that encircle the 4" glass lens.
  • 5" lamp uses selectable 18 warm or 18 cold white LEDs for bright, clear illumination
  • 1" 12D magnifier (4 x magnification) for reading tiny text on electronic components
  • Stands on its own with a 6" x 7" base or clamps to a desk for more secure placement
  • Touch switch toggles between warm white, cold white and off for ease of use
  • LEDs mean long lifetime and reduced risk of breakage vs. standard bulbs
  • Includes a 5 ft.USB cord that plugs into any USB-A powered port
  • 10" goose neck with a scratch resistant glass lens
CLEARANCE $14.61
Save $25.38 (63%)
80 In Stock
We'll send you an email when USB Powered Magnifying 4" 3D + 12D Glass Lens Desk Lamp with Base, Clamp and Dual Color LED-White is back in stock or available for preorder.
Order in the next 4 hr 22 min to ship today. Details
This desktop/clamp on LED magnifier work lamp uses 18 warm or 18 cold white high-output, low power consumption LEDs to illuminate whatever you are working on. The 3D diopter (1.75 x magnification) 4" glass lens with added 1" 12D (4 x magnification) diopter lens magnifies at a level of detail that would be impossible or strain-inducing for the eye alone. The convenient size means that you won't have trouble finding storage for this magnifier, and it's easy to use anywhere there's access to USB power. Slide the lamps base off and use the clamp mount to take up less space while making it more secure for a workbench application.
Part Number350-026
UPC848864068695
Weight2.8
