  • Under-Dash Mount USB Extension Cable for Car Audio with Cover DC 5V Auto Vehicle Charging Adapter for Mobile Phone USB Port Black Plastic
CLEARANCE Under-Dash Mount USB Extension Cable for Car Audio with Cover DC 5V Auto Vehicle Charging Adapter for Mobile Phone USB Port Black Plastic
Parts ExpressPart # 130-018
More car audio systems today feature a USB connection than ever before. Place the USB port anywhere you like with this 3.3 ft. USB extension cable and mount. Rubber cover helps keep out dust and moisture.
  • Relocate a manufacturer's USB jack
  • Drill a mounting hole and snap into place
  • Attached rubber cap provides dust and moisture protection, plus a clean and professional installation
  • Includes optional mounting bracket
CLEARANCE $5.98
Save $4.01 (40%)
126 In Stock
We'll send you an email when Under-Dash Mount USB Extension Cable for Car Audio with Cover DC 5V Auto Vehicle Charging Adapter for Mobile Phone USB Port Black Plastic is back in stock or available for preorder.
USB now synonymous with car audio, and this 3.3 ft. (1 meter) extension cable with mount lets you place a USB port wherever you like. Designed to mount easily and inconspicuously into your vehicle, it only requires you drill a 3/4" hole and snap the jack into place. The USB port includes an attached rubber cap to dust and moisture out.
When there is nowhere to drill a hole, the included mounting bracket can be fastened to any panel or even inside the glove compartment or console. Connect to the back of your head unit or relocate the manufacture installed USB jack from an awkward location to an easier to use location. The mount is built to work with 3/16" body diameter screws. Compatible with all USB 2.0 devices and older.
Dimensions:• Connector head: Overall diameter: 1", Cutout: 3/4" • Connector mount: 2-5/16" W (base), 1-3/16" W (top), 1-5/16" H, 3/4" D.
Part Number130-018
UPC848864066424
Weight0.15
Cable Length3.3feet
Cable TypeUSB A Male to A Female
Jacket ColorBlack
