  • USB-C to Microphone Headset Dual 3.5mm Adapter
CLEARANCE USB-C to Microphone Headset Dual 3.5mm Adapter
Parts ExpressPart # 180-965
Instantly turn your USB-C port on your smartphone or tablet into a 3.5 mm stereo headphone jack and a 3.5 mm microphone input jack with this USB-C adapter.
  • Plug-n-play enables multimedia headphones with two 3.5mm plugs to work on smartphones and tablets with a USB-C jack
  • Turns the USB-C port into a separate 3.5 mm stereo audio out and 3.5mm audio input jacks without any extra software
  • Pictures on the adapter quickly identify which jack is for a headphone and which is for a microphone
  • USB-C plug and the 3.5 mm ports are both surrounded by metal for durability.
CLEARANCE $4.60
MSRP: $19.99
Save $15.39 (77%)
37 In Stock
We'll send you an email when USB-C to Microphone Headset Dual 3.5mm Adapter is back in stock or available for preorder.
Use this USB-C adapter to enable a dual 3.5 mm plug multimedia headphone to plug into your smartphone or tablet for more private video conferencing. Shield out the noises around you while video conferencing with clients and avoid disturbing fellow employees by cutting out built-in/external speakers. The adapter comes with a 4" pigtail to prevent stress on your USB-C port and is only 1.3" W x 0.42" H x 1.19" D on the 3.5 mm side. The USB-C plug and the 3.5 mm ports are both surrounded by metal for durability.
This USB-C adapter also enables you to send stereo audio output and receive mono audio input from devices that have no 3.5 mm jacks. Many smartphones and tablets are eliminating 3.5 mm jacks and only having USB-C ports. This adapter enables you to send stereo audio output to amplifiers, mixers and recorders when no 3.5 mm headphone jack is available. The adapter also allows you to send mono audio input from external microphones into your device that only has a USB-C port.
Part Number180-965
UPC848864065618
