  • USB-C PD and USB-A QC3.0 Dual Lighter Socket Replacement
CLEARANCE USB-C PD and USB-A QC3.0 Dual Lighter Socket Replacement
Parts ExpressPart # 265-263
Upgraded or add a 12 VDC socket with one QC 3.0 USB-A port and one PD 3.0 USB-C port for maximum charging power for your smartphone or tablet.
  • Replace low-amperage preinstalled USB sockets in vehicles
  • Charge tablets and smartphones faster with a QC 3.0 and PD 3.0 port with combined 36W output
  • Includes rubber cap to meet IP65 rating to help keep dust and moisture out when not in use
  • LED display for reading voltage input
  • Includes mounting ring and two 14 to 16 gauge quick disconnects
CLEARANCE $8.53
Save $11.46 (57%)
31 In Stock
We'll send you an email when USB-C PD and USB-A QC3.0 Dual Lighter Socket Replacement is back in stock or available for preorder.
Some vehicles have USB charging sockets that are 1A or less and won't charge your smartphone when playing music or using a GPS app. This Dual USB socket replaces these sockets, with little modification, and gives you one QC 3.0 USB-A port and one PD 3.0 USB-C port for super-fast charging. Newer smartphones and tablets communicate with these new USB ports to determine what voltage your device handles to charge at its fastest rate. It won’t harm older devices that still charge at 5 VDC.
Replace the current lighter/accessory socket or add USB sockets to a vehicle without a 12 VDC accessory port. This eliminates having to carry around a 12 VDC to 5VDC adapter or portable charging source. You just need a 1-1/8" hole to mount the dual USB socket into any type of vehicle. The included rubber cover keeps dust and moisture out.
Specifications: • Voltage input: 12-24 VDC • DC voltage output: USB-A 5V @ 4.5A, 9V @ 3A port, 12V @ 2.5A and USB-C 5V @ 3A, 9V @ 3A, 12V @2.5A, 15V @ 2A, 20V @ 1.5A • Maximum current output shared: 36W • Maximum dimensions: 1.44" Dia. x 2.08" L (36.75 x 52.71 mm) with terminals • Terminal dimensions: 0.25" W x 0.46" L x 0.032" D (6.31 x 11.68 x 0.82 mm) • Mounting hole: 1-1/8" (28.5 mm).
Part Number265-263
UPC848864069500
Weight0.07
Center/Tip PolarityUSB
Current Capacity5000mA
DC Output VoltageVariable
Input Voltage12 VDC
Plug SizeUSB
