  • USB-C Hub 3-In-1 Multiport Adapter with HDMI 4K USB-A 3.0 Port and USB-C PD Charging Port
Parts ExpressPart # 181-793
This 3-in-1 adapter converts USB-C 3.0 ports into HDMI 4K Ultra HD, and USB-A 3.0 ports plus has a built-in USB-C 3.0 PD 60W charging port. It works with most Apple Macbook Pros, Android smartphones, tablets, and laptops with USB-C ports. Always be ready to do a video presentation wherever you are by having this 3-in-1 adapter available.
  • Provides screen resolution up to 4Kx2K / 3840x2160 @ 30Hz and 8-channel digital audio
  • Supports Apple MacBook, Chromebook Pixel, MS Surface Book 2 & Windows Laptop with USB-C or Thunderbolt 3 port
  • Works with most smartphones including Samsung Galaxy series to convert USB-C to HDMI
  • Built-in USB-C 3.0 port enables input and output charging
  • USB-C connected devices must support DP Alt Mode or Thunderbolt 3 connector
  • The hi-speed USB-C 3.0 male converts to USB-A 3.0 female connector with 4" cable (no external power required)
  • CE and FCC certified
Your Price: $16.98
MSRP: $29.99
Save $13.01 (43%)
We'll send you an email when USB-C Hub 3-In-1 Multiport Adapter with HDMI 4K USB-A 3.0 Port and USB-C PD Charging Port is back in stock or available for preorder.
Order in the next 3 hr 31 min to ship today. Details
Most laptops and other similar electronic devices have USB-C ports instead of USB-A ports. The problem is that most people still have USB-A devices. This 3-in-1 adapter solves this issue plus gives you an HDMI 4K video port in case you need to hookup a display that only supports HDMI inputs. The adapter works with USB-C/Thunderbolt 3, Android smartphones, tablets and other devices that support USB-C video output and connects them to a flat panel monitor, projector, or HDTV with a single HDMI cable (sold separately). Its hot-plug provides high-bandwidth to support large, high-resolution screens. Provides screen resolution up to 4Kx2K / 3840x2160 @ 30Hz with digital audio. The built-in USB-C port enables you to keep your laptop charged while converting to HDMI 2.0, or charge your smartphone with USB PD 65W technology. The 0.41" wide USB-C shell fits into most smartphones with cases. The total size of the 3-port shell is 2.25" W x 2.07" D x 0.5" H.
Part Number181-793
UPC848864070285
Weight0.12
