  • USB A Male to USB A Female 90 Degree Adapter
CLEARANCE USB A Male to USB A Female 90 Degree Adapter
Parts ExpressPart # 130-580
Have you ever tried to connect to a USB port in a tight location and the end result was a broken cable, or a failed connection? Look no further than this 90° USB adapter to remedy the issue. This adapter allows you to connect your USB cable to a port in close proximity to other objects.
  • Supports the standard USB 2.0 connection
  • Nickel plated for an enhanced connection
CLEARANCE $1.29
Save $1.70 (57%)
607 In Stock
We'll send you an email when USB A Male to USB A Female 90 Degree Adapter is back in stock or available for preorder.
Connecting to USB ports in cramped spaces is often times a problematic task. Remedying the problem is easy when using this right-angle USB adapter.
Specifications: • Connection: Male USB A to Female USB A • Dimensions: 1" x 0.7" x 1.3".
Part Number130-580
UPC848864050737
