  • USB-A Female 90 Degree Solder Terminal PCB Mount Connector 5-Pack
CLEARANCE USB-A Female 90 Degree Solder Terminal PCB Mount Connector 5-Pack
Parts ExpressPart # 090-132
PCB mount USB connectors offer a do-it-yourselfer the ability to prototype computer peripherals using standard USB size connectors. These USB A female-type connectors feature 90° PCB mounting.
  • 90° PCB mounting for flat profile applications
  • Economical 5-pack
CLEARANCE $1.89
MSRP: $5.99
Save $4.10 (68%)
1 In Stock
We'll send you an email when USB-A Female 90 Degree Solder Terminal PCB Mount Connector 5-Pack is back in stock or available for preorder.
PCB mount USB connectors offer a do-it-yourselfer the ability to prototype computer peripherals using standard USB size connectors. These USB A female-type connectors feature 90° PCB mounting that make them perfect for making sockets to receive USB-A dongles or thumb drives.
Specifications: • Dimensions: 0.53" W x 0.21 H x 0.58" D (13.32 x 6 x 14.7 mm) without terminals • Terminal dimensions: 0.156" L x 0.025" W x 0.01" D (4 x 0.66 x 0.25 mm) • Solder encore dimensions: 0.15 L x 0.074" W x 0.015" D (2.92 x 1.87 x 0.4 mm) • Space between terminals: 0.07" (1.75 mm).
Part Number090-132
UPC848864051970
Unit of MeasurePackages
