The Topping MX3 amplifier and DAC delivers a powerful 40 Watts per channel. A variety of input options that include Bluetooth, USB, COAX, optical, and AUX allow you to connect to almost any device. The MX3 features an auto on/off that synchronizes with your digital inputs (does not work with AUX in). Control the tone of the amp with selectable treble and bass controls. The amplifier features a dB/step volume display with adjustable brightness. High quality electrical components deliver a detailed, audiophile sound. Hi-Fi DAC sample rates will bring your music to life with precision, clarity, and detail. Topping has not only delivered an amazing sound, the exquisite aluminum case provides a modern, clean aesthetic.
Specifications: • Inputs: COAX, optical, USB, AUX • Outputs: Active subwoofer (RCA), banana jack, BTL speaker, 3.5 mm headphone • Signal input: BT/USB/OPT/COAX/AUX • Power input: DC24V/3.75A • Bluetooth <10m • Certifications: CE, RoHS, FCC • Dimensions: 7.2" x 4.8" x 1.5".
Speaker output specifications: • Output: 38W x 2 (8 ohms), 40W x 2 (4 ohms) • THD+N (A weighting): <10% @ 1 kHz • SNR (A weighting): >91 dB @ 1 kHz • Frequency response: 20-20,000 Hz • Output voltage: 46Vpp • Noise <0.5mVrms • Crosstalk: -75 dB @ 1 kHz • Output impedance: <0.2 ohms • Gain: 29.6 dB • Suitable load impedance: 16 - 300 ohms.
Headphone output specifications: • Output: 257mW x 2 (8 ohms), 42mW x 2 (4 ohms) • THD+N (A weighting): <0.006% @ 1 kHz • SNR (A weighting): >103 dB @ 1 kHz • Frequency response: 20-20,000 Hz • Output voltage: 10Vpp • Noise <18uVrms • Crosstalk: -93 dB @ 1 kHz • IMD CCIF: -81 dB • IMD SMPTE: -78 dB • Gain: 11.6 dB • Output impedance: <0.2 ohms • Suitable load impedance: 4 - 8 ohms.
DAC Specifications: • USB in: 44.1-96 kHz / 16-24 bit • OPT/COAX in: 44.1-192 kHz / 16-24 bit • Bluetooth: HFPV1.6, A2DPV1.2, AVRCPV1.4.
