  • Timpano Audio TPT-ST3 Black 4" Round Super Tweeter Pair 4 Ohm
Timpano AudioPart # 294-3388
Model: TPT-ST3 BLACK
Timpano Audio's TPT-ST3 horn loaded super tweeter pair can provide high output in systems where space is at a premium. The aluminum diaphragm and horn loaded design delivers dynamic and detailed response even at high output levels. Thanks to the flat faceplate, the TPT-ST3 has a clean and modern look.
  • Response up to 22,000 Hz for incredible accuracy and detail
  • 105 dB sensitivity to deliver high output even with lower power designs
  • Aluminum diaphragm produces accurate response and high efficiency
  • Included high pass crossover protects tweeter from damaging low frequencies
See all items in Horn Loaded Tweeters & Midranges
Your Price: $22.95
MSRP: $28.69
Save $5.74 (20%)
We'll send you an email when Timpano Audio TPT-ST3 Black 4" Round Super Tweeter Pair 4 Ohm is back in stock or available for preorder.
Order in the next 4 hr 47 min to ship today. Details
When space is at a premium, but you need high output, the TPT-ST3 super tweeter pair from Timpano Audio is ideal. The aluminum diaphragm and 1" voice coil can handle up to 60 watts RMS. That, combined with 105 dB efficiency, gives the TPT-ST3 incredible long term output capability for its size. With a frequency response of 2,000 to 22,000 Hz, this horn loaded bullet tweeter will provide an extremely detailed and dynamic sound. All of this makes the TPT-ST3 super tweeter pair a fantastic value.
Specifications: • Power handling: 60 watts RMS/120 watts peak • VCdia: 1" • Impedance: 4 ohms • Frequency response: 2,000-22,000 Hz • SPL: 105 dB 1W/1m • Dimensions: 3.7" Dia x 1.8" D. • Baffle cutout diameter (front mount): 2.87" • Weight: 2.64 lbs/pair.
Note: The TPT-ST3 is sold in pairs.
BrandTimpano Audio
ModelTPT-ST3 BLACK
Part Number294-3388
UPC611056239285
Unit of MeasurePairs
Weight2.8
Diaphragm MaterialAluminum
Power Handling (RMS)60 Watts
