  • Timpano Audio TPT-ST1 1" Soft Dome Tweeter Pair 4 Ohm
Timpano AudioPart # 294-3360
Model: TPT-ST1
Timpano Audio's TPT-ST1 compact dome tweeter pair makes it easy to add high frequency to any system. These compact dome tweeters include mounting options to fit almost every installation.
  • 1" dome produces wide dispersion for excellent off axis response
  • Ultra compact design for installation almost anywhere
  • 100 dB sensitivity for high output even with little power
  • Three different simple mounting options to fit almost every installation
Your Price: $9.95
MSRP: $12.44
Save $2.49 (20%)
We'll send you an email when Timpano Audio TPT-ST1 1" Soft Dome Tweeter Pair 4 Ohm is back in stock or available for preorder.
The TPT-ST1 dome tweeter pair from Timpano Audio makes it easy to add a little extra high frequency detail to any car stereo system. These compact tweeters a small enough to install almost anywhere. With high efficiency and wide dispersion, the TPT-ST1 has enough output capability to keep up with most car stereo systems. The included surface mount, angle mount, and adjustable angle mount brackets make it easy to install these into almost any system for optimum performance. All mounting hardware is included.
Specifications: • Power handling: 35 watts RMS/150 watts max • Impedance: 4 ohms • Frequency response: 5,000-20,000 Hz • SPL: 100 dB 2.83V/1m • Lead Length: 20" • Dimensions: Overall diameter: 1.25"; Height: 0.5".
BrandTimpano Audio
ModelTPT-ST1
Part Number294-3360
UPC611056238660
Unit of MeasurePairs
Weight0.15
Tweeter TypePoly / Mylar Dome
Power Handling (RMS)35 Watts
