  • Timpano Audio TPT-MR8-4 Slim 8" Midrange Speaker 4 Ohm
CLEARANCE Timpano Audio TPT-MR8-4 Slim 8" Midrange Speaker 4 Ohm
Timpano AudioPart # 294-3308
Model: TPT-MR8-4 Slim
Timpano Audio's TPT-MR8-4 Slim 8" midrange driver provides remarkably smooth response in the vocal region even at high SPL. With a high Q and a mounting depth of just over 2-1/2", this driver is idea for use in low profile installations, such as car doors. Capable of handling 200 watts RMS and with a sensitivity of 95 dB, the TPT-MR8-4 Slim is designed to deliver continuous high SPL output.
  • Vented pole piece keeps voice coil cool for continuous high output
  • Only 2.56" deep for installations where space is at a premium
  • 95 dB sensitivity to provide high SPL when needed
  • Naturally damped cone for natural vocal reproduction and flat response
We'll send you an email when Timpano Audio TPT-MR8-4 Slim 8" Midrange Speaker 4 Ohm is back in stock or available for preorder.
The TPT-MR8-4 Slim 8" midrange from Timpano Audio can perform well in a professional sound system, but has been designed for use in the mobile audio market. With a naturally damped paper cone and double roll cloth surround, this driver keeps resonances under control for natural response throughout the sensitive vocal range. The vented pole piece and 2" voice coil are designed to dissipate heat allowing the TPT-MR8-4 Slim to handle 200 watts of continuous power. The large ferrite motor is less susceptible to heat than neodymium to minimize power compression when driven at high output for long periods of time. Requiring just over 2-1/2" of depth, this driver is perfect for the low profile installations that are necessary in today's high output mobile sound systems.
BrandTimpano Audio
ModelTPT-MR8-4 Slim
Part Number294-3308
UPC611056239032
Weight6.25
Nominal Diameter8"
Power Handling (RMS)200 Watts
Power Handling (MAX)400 Watts
Frequency Response95 to 6,500Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)102.1Hz
DC Resistance (Re)3.2Ω
Mechanical Q (Qms)8.6
Electromagnetic Q (Qes)0.68
Total Q (Qts)0.63
Compliance Equivalent Volume (Vas)0.38ft³
BL Product (BL)7.4T·m
Diaphragm Mass Inc. Airload (Mms)18g
Surface Area of Cone (Sd)241cm²
Cone MaterialPaper
Surround MaterialCloth
Baffle Cutout Diameter7.16"
Depth2.56"
Sealed Volume0.65ft³
Sealed F3128.6Hz
Vented Volume0.88ft³
Vented F380.3Hz
