  • Timpano Audio TPT-EQ7 7 Band Graphic Equalizer
CLEARANCE Timpano Audio TPT-EQ7 7 Band Graphic Equalizer
Timpano AudioPart # 294-3382
Model: TPT-EQ7
For easy audio adjustments on the fly, Timpano Audio's TPT-EQ7 1/2 DIN 7 band graphic equalizer is an excellent choice. Featuring 7 adjustable frequencies, 2 inputs, subwoofer level control, 6 channel output, and selectable illumination color, the TPT-EQ7 is an unbeatable value.
  • Plus or minus 12 dB on each of the 7 bands for ultimate audio control
  • Up to 8 volt RCA line output for low noise even with long runs
  • Switchable red or blue illumination to integrate visually with most systems
  • Adjustable subwoofer level control to fine tune your bass on the fly
We'll send you an email when Timpano Audio TPT-EQ7 7 Band Graphic Equalizer is back in stock or available for preorder.
The compact TPT-EQ7 graphic equalizer from Timpano Audio makes it easy to adjust your sound system for optimum performance on the fly. The slim 1/2 DIN chassis is small enough to add to most of today's installations without requiring extensive customization. The flexibility of 7 different adjustable frequencies (±12 dB each) lets you change just the frequency you need to get your system sounding its best. The separate subwoofer output with adjustable level control makes it easy to instantly boost or cut the bass output whenever you want. Two selectable inputs allow you to efficiently choose between your head unit and any other audio source. Also, capable of 8 volts of output, the TPT-EQ7 has enough power to minimize induced noise when be added to almost any system, even when using long RCA wires. Finally, to visually integrate with most existing installations, you have the option of selecting between red or blue back lighting on the front panel. With all these features and solid performance, Timpano's TPT-EQ7 is an unbeatable value!
Specifications: • Inputs: 4 RCA (selectable stereo main and stereo auxiliary) • Outputs: 6 RCA (stereo front, stereo rear, and stereo subwoofer) • Level adjustments: Subwoofer, master volume, front/rear fader • Bands: 50, 125, 320, 750, 2,200, 6,000 and 16,000 Hz (±12 dB each) • Output voltage: 8V RMS • Supply voltage: 10 – 16 VDC • Dimensions: 1" H x 7" W x 5" D • Weight: 1 lb.
BrandTimpano Audio
ModelTPT-EQ7
Part Number294-3382
UPC611056238721
Weight1.6
