  • Timpano Audio TPT-5000EQ 2 Ohm 5,000 Watt Mono Car Audio Amplifier
CLEARANCE Timpano Audio TPT-5000EQ 2 Ohm 5,000 Watt Mono Car Audio Amplifier
Timpano AudioPart # 294-3068
Model: TPT-5000EQ 2 Ohms
Read 1 Review or
The Timpano TPT-5,000EQ 2 Ohm is a very efficient Class D full range mono car audio amplifier that is extremely compact for its power output.
  • Brazilian class D technology provides extreme efficiency power output
  • Very light weight at 9 lbs.
  • Compact design allows for installation virtually anywhere
  • Built-in EQ and crossover functions
We'll send you an email when Timpano Audio TPT-5000EQ 2 Ohm 5,000 Watt Mono Car Audio Amplifier is back in stock or available for preorder.
Timpano amplifiers offer high power output in a compact size, and the TPT-5,000EQ 2 Ohm is no exception. The Brazilian Class D design allows for an efficiency between 85%-95%.
Due to its compact size and light weight, the TPT-5,000EQ 2 Ohm can be used in installations that most car audio amplifiers would not fit.
• Number of Channels: 1
• RMS Power at 2 Ohms 12.6V: 5000W
• RMS Power at 4 Ohms 12.6V: 3050W
• RMS Power at 2 Ohms 14.4V: 5500W
• RMS Power at 4 Ohms 14.4V: 3550W
• Supply Voltage: 9.5 ~ 15V
• Frequency Response: 10 Hz ~ 15 kHz
• Crossover Low Pass: 50 Hz ~ 15 kHz
• Crossover High Pass: 10 Hz ~ 700 Hz
• Signal to Noise: >90 dB
• Harmonic Distortion: <0.9 % THD
• Input Sensitivity: 0.2V
• Input Impedance: 26K Ohms
• Impedance Output: 2 Ohms
• Consumption with Signal Musical: 3.1A ~ 240A
• Consumption with Signal Bass: 3.1A ~ 480A
• Dimensions (L x W x H): 11.57" x 12.20" x 3"
BrandTimpano Audio
ModelTPT-5000EQ 2 Ohms
Part Number294-3068
UPC611056238820
Weight10.45
