  • Timpano Audio TPT-10500EQ 1 Ohm 10,500 Watt Mono Car Audio Amplifier
CLEARANCE Timpano Audio TPT-10500EQ 1 Ohm 10,500 Watt Mono Car Audio Amplifier
Timpano AudioPart # 294-3074
Model: TPT-10500EQ 1 Ohm
The Timpano TPT-10,500EQ 1 Ohm is a very efficient Class D full range mono car audio amplifier that is extremely compact for its power output.
  • Brazilian class D technology provides extreme efficiency power output
  • Very light weight at 16.5 lbs.
  • Compact design allows for installation virtually anywhere
  • Built-in EQ and crossover functions
We'll send you an email when Timpano Audio TPT-10500EQ 1 Ohm 10,500 Watt Mono Car Audio Amplifier is back in stock or available for preorder.
Timpano amplifiers offer high power output in a compact size, and the TPT-10,500EQ 1 Ohm is no exception. The Brazilian Class D design allows for an efficiency between 85%-95%.
Due to its compact size and light weight, the TPT10,500EQ 1 Ohm can be used in installations that most car audio amplifiers would not fit.
• Number of Channels: 1
• RMS Power at 1 Ohm 12.6V: 10500W
• RMS Power at 2 Ohm 12.6V: 6400W
• RMS Power at 4 Ohm 12.6V: 3900W
• RMS Power at 1 Ohm 14.4V: 11600W
• RMS Power at 2 Ohm 14.4V: 7300W
• RMS Power at 4 Ohm 14.4V: 4800W
• Supply Voltage: 9.5 ~ 15V
• Frequency Response: 10 Hz - 15 kHz
• Crossover Low Pass: 50 Hz ~ 15 kHz
• Crossover High Pass: 10 Hz ~ 700 Hz
• Signal to Noise: >90 dB
• Harmonic Distortion: <0.9 % THD
• Input Sensitivity: 0.2V
• Input Impedance: 25K ohms
• Impedance Output: 1 ohm
• Consumption with Signal Musical: 6.7A ~ 495A
• Consumption with Signal Bass: 6.7A ~ 990A
• Dimensions (L x W x H): 11.57" x 20" x 3"
BrandTimpano Audio
ModelTPT-10500EQ 1 Ohm
Part Number294-3074
UPC611056238851
Weight17.8
