  • Thermocool 110 VAC Muffin Cooling Fan 92 x 25mm Sleeve Bearing 28 CFM
ThermocoolPart # 250-014
Model: G9225HAS
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
Your Price: $10.49
MSRP: $18.99
Save $8.50 (45%)
8 In Stock
We'll send you an email when Thermocool 110 VAC Muffin Cooling Fan 92 x 25mm Sleeve Bearing 28 CFM is back in stock or available for preorder.
Order in the next 1 hr 20 min to ship today. Details
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Terminal connection • 0.14 amps • 2300 RPM • 34dB noise level • 28CFM air flow • Dimensions: 92 mm (H) x 92 mm (W) x 25 mm (D).
BrandThermocool
ModelG9225HAS
Part Number250-014
UPC656403892256
Weight0.5
Bearing TypeSleeve Bearing
Operating Voltage110~120 VACV
Size92
