Thermocool 110 VAC Muffin Cooling Fan 80 x 38mm Sleeve Bearing 23 CFM
We'll send you an email when Thermocool 110 VAC Muffin Cooling Fan 80 x 38mm Sleeve Bearing 23 CFM is back in stock or available for preorder.
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Sleeve bearing • Lead wire connection • 0.14 amps • 2400 RPM • 28dB noise level • 23CFM air flow • Dimensions: 80 mm (H) x 80 mm (W) x 38 mm (D).
Product Details | |
Brand | Thermocool |
Model | G8038HAS |
Part Number | 250-012 |
UPC | 656403880383 |
Unit of Measure | Each |
Weight | 0.6 |
Product Specifications | |
Bearing Type | Sleeve Bearing |
Operating Voltage | 110~120 VACV |
Size | 80 |
