  • Thermocool 110 VAC Equipment Cooling Fan 172 x 150 x 51mm Ball Bearing 176 CFM
ThermocoolPart # 250-030
Model: G17050-A1
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
Your Price: $26.49
Save $17.50 (40%)
10 In Stock
We'll send you an email when Thermocool 110 VAC Equipment Cooling Fan 172 x 150 x 51mm Ball Bearing 176 CFM is back in stock or available for preorder.
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Ball bearing • Terminal connection • 0.48 amps • 2600 RPM • 54dB noise level • 176CFM air flow • Dimensions: 172 mm (H) x 150 mm (W) x 51 mm (D).
BrandThermocool
ModelG17050-A1
Part Number250-030
UPC656403817501
Weight1.9
Bearing TypeBall Bearing
Operating Voltage110~120 VACV
Size172 x 150
