  • Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Ball Bearing 72 CFM
CLEARANCE Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Ball Bearing 72 CFM
ThermocoolPart # 250-020
Model: G12038MA8
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
We'll send you an email when Thermocool 110 VAC Muffin Cooling Fan 120 x 38mm Ball Bearing 72 CFM is back in stock or available for preorder.
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120V AC, 60 Hz • Ball bearing • Terminal connection • 0.22 amps • 2200 RPM • 39dB noise level • 72CFM air flow • Dimensions: 120 mm (H) x 120 mm (W) x 38 mm (D).
BrandThermocool
ModelG12038MA8
Part Number250-020
UPC656403812322
Weight1
Bearing TypeBall Bearing
Operating Voltage110~120 VACV
Size120
