  • Thermocool 110 VAC Muffin Cooling Fan 120 x 25mm Sleeve Bearing 57 CFM
ThermocoolPart # 250-016
Model: G12025HAS
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product.
Your Price: $14.98
MSRP: $21.99
Save $7.01 (32%)
Quantity:Qty: 1-9 $14.98/ea
Quantity:Qty: 10+ $14.53/ea
11 In Stock
We'll send you an email when Thermocool 110 VAC Muffin Cooling Fan 120 x 25mm Sleeve Bearing 57 CFM is back in stock or available for preorder.
Thermocool axial fans provide enhanced cooling for a variety of electronic devices. Leading air flow technology is designed into every Thermocool product resulting in reduced turbulence, low noise levels and a more energy efficient product. Thermocool fans are ideal for use in computer systems, portable CD and DVD players, stereo components, overhead projectors, laptop computers, and many other electronic applications where circulation is a key concern.
Specifications: • Power: 120 VAC, 60 Hz • Sleeve bearing • Terminal connection • 0. 20 amps • 2300 RPM • 39 dB noise level • 57CFM air flow • Dimensions: 120 mm H x 120 mm W x 25 mm D.
BrandThermocool
ModelG12025HAS
Part Number250-016
UPC656403812254
Weight0.75
Bearing TypeSleeve Bearing
Operating Voltage110~120 VACV
Size120
