Get rid of the clutter of USB adapters while freeing up the AC outlets in your home with the handy USB power strip. Easily power up or charge up to 10 USB devices at the same time. This power strip has a similar form factor as traditional power strips, but with the convenience of directly connecting modern USB devices for power and charging.
The array of USB ports have different current capacities labeled from 2.1A to 0.5A so you know just how much current is being delivered to your phone, tablet, or any other electronic equipment that relies on USB for power. When the power strip is switched to the "on" position, a tiny red LED illuminates so you know your devices are ready to charge.
Specifications: • Outlets: 10 USB • USB amperage: (1) 2.1A port, (2) 1A ports, (7) 0.5-1A ports • Input: 100-240 VAC • Output: 5 VDC, 6A • On/off switch • Cord length: 5 ft. • Dimensions: 1-7/8" W x 1-1/4" H x 9-1/2" D.
Note: Any device that is plugged into this power strip will only take the current that is needed to power up or charge. You will not damage your device by plugging it into a higher rated USB port than it needs. Conversely, be sure not to under-power your device. Doing so may damage this power strip.
