  • Techflex 1/2" Expandable Sleeving 25 ft. Neon Yellow
CLEARANCE Techflex 1/2" Expandable Sleeving 25 ft. Neon Yellow
TechflexPart # 082-362
Model: PT3NY25-C
Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light.
  • Professional look for custom cable assemblies
  • Bundles cables and organizes wires
  • Easy to install, lightweight and flexible
  • Abrasion, chemical and U/V resistant
  • Wide operating temperature
  • Available in a variety of colors and sizes
We'll send you an email when Techflex 1/2" Expandable Sleeving 25 ft. Neon Yellow is back in stock or available for preorder.
Techflex Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light. Due to its expandable nature, the braiding will easily slip over large connectors and then "form-fit" over cables for quick and easy installations. Because it is available in a variety of colors and sizes, it can be used to "color code" wires for easy identification. It is braided from .010" monofilament polyester yarn that can withstand temperature extremes from -103° F to +257° F, making it perfect for automotive applications. Flexo can be terminated using electrical tape, wire ties or heat shrink. For a professional look, and to slide over large connectors, we recommend using our 3-to-1 Ratio heat shrink which is also available in a variety of colors and sizes. Braiding must be cut with a hot knife to prevent unraveling and has a melting temperature of +446° F. Sold in 25 ft. lengths.
Specifications: • Size I.D.: 1/2" • Size Range (min~max): 1/4"~3/4" • Color: Neon Yellow.
BrandTechflex
ModelPT3NY25-C
Part Number082-362
UPC738854005598
Weight0.26
ColorNeon Yellow
Nominal I.D.0.5"
Sleeving TypeExpandable
