  • Tang Band W8-1363SB 8" Subwoofer
Tang BandPart # 264-833
Model: W8-1363SB
Amazing bass in a compact package! This one-of-a-kind subwoofer features outstanding Xmax and a powerful neodymium motor. A wide roll rubber surround, heavy-duty paper cone, flat spider, and large 4-layer voice coil give impressive bass and high power handling.
We'll send you an email when Tang Band W8-1363SB 8" Subwoofer is back in stock or available for preorder.
Amazing bass in a compact package! This one-of-a-kind subwoofer features outstanding Xmax and a powerful neodymium motor. A wide roll rubber surround, heavy-duty paper cone, flat spider, and large 4-layer voice coil give impressive bass and high power handling. Venting under the spider and through the pole reduce compression and maximize heat dissipation. This is the ultimate small box 8" subwoofer!
BrandTang Band
ModelW8-1363SB
Part Number264-833
UPC844632008443
Weight5.8801
Nominal Diameter8"
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response30 to 800Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)30Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)0.66mH
Mechanical Q (Qms)4.26
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.29
Compliance Equivalent Volume (Vas)0.67ft³
Mechanical Compliance of Suspension (Cms)0.28mm/N
BL Product (BL)14.02T·m
Diaphragm Mass Inc. Airload (Mms)99.78g
Maximum Linear Excursion (Xmax)12mm
Surface Area of Cone (Sd)220cm²
Cone MaterialPaper
Magnet MaterialNeodymium
Overall Outside Diameter8.62"
Baffle Cutout Diameter7.2"
Depth5.27"
Sealed Volume0.3ft³
Sealed F388.2Hz
Vented Volume0.75ft³
Vented F329.9Hz
