  • Tang Band W6-2100 6-1/2" RBM Flat Panel Subwoofer 4 Ohm
Tang BandPart # 264-954
Model: W6-2100
Tang Band has expanded their line of impressive RBM subwoofers to include the W6-2100 6-1/2" driver. This oversized 6-1/2" is built like a tank and uses a unique, patented design, which eliminates the spider while delivering 10 mm of linear excursion.
  • Amazing 10 mm of excursion and low Fs for unmatched low frequency from a driver this size
  • Large 2" diameter voice coil with extensive venting for high power handling
  • No spider thanks to the patented dual cone, dual surround suspension
  • Completely linear travel up to the limits of excursion
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $199.98
MSRP: $259.99
Save $60.01 (23%)
Quantity:Qty: 50+ $199.98/ea
Out of Stock
We'll send you an email when Tang Band W6-2100 6-1/2" RBM Flat Panel Subwoofer 4 Ohm is back in stock or available for preorder.
Ships in 90-120 days, minimum order quantity 50 pcs.
Tang Band's unique W6-2100 oversized 6-1/2" subwoofer is in a class of its own. This driver uses a unique suspension consisting of dual surrounds and no spider for maximum linearity throughout its 10 mm of xmax and beyond. With extensive venting of the voice coil, cone, and pole piece the W6-2100 can handle up to 110 watts max without an issue while delivering powerful yet extremely clean frequency response into the bottom octave. In addition, the extended back plate prevents the voice coil from bottoming out when driven well beyond xmax.
Tang Band designed their revolutionary RBM (Real Balanced Mode) flat subwoofers for ultra-linear operation, while remaining as thin as possible. The secret to their low distortion performance is in the patented symmetrical suspension system.
While most subwoofers rely upon a spider/surround combination to keep the cone travel linear, Tang Band has developed a new injection molding process that incorporates front and rear cones, as well as dual opposed surrounds. The added mass of the cone/surround assembly also reduces free air resonance.
BrandTang Band
ModelW6-2100
Part Number264-954
UPC848864023755
Weight11.45
Nominal Diameter6-1/2"
Bolt Circle Diameter9.5
Power Handling (RMS)55 Watts
Power Handling (MAX)110 Watts
Frequency Response29 to 300Hz
Sensitivity81dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)29Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.45mH
Mechanical Q (Qms)5.2
Electromagnetic Q (Qes)0.48
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)0.57ft³
Mechanical Compliance of Suspension (Cms)0.38mm/N
BL Product (BL)10.44T·m
Diaphragm Mass Inc. Airload (Mms)79.8g
Maximum Linear Excursion (Xmax)10mm
Cone MaterialPoly Composite
Voice Coil FormerAluminum
Overall Outside Diameter8.375" x 8.375": Diagonal 10.125"
Baffle Cutout Diameter7.625"
Depth4.5"
Sealed Volume0.25ft³
Sealed F353.5Hz
Vented Volume0.6ft³
Vented F328.1Hz
