  • Tang Band W5-2053 5" RBM Flat Panel Subwoofer 4 Ohm
Tang BandPart # 264-953
Model: W5-2053
The 5" W5-2053 subwoofer from Tang Band is built using propietary RBM surround technology for ultra-linear output down to 35 Hz.
  • Small design for space-limited applications
  • Patented dual cone, dual surround subwoofer
  • Ultra-linear operation for low non-linear distortion
  • Huge 1-1/2" voice coil with 8 mm of Xmax and extensive cooling
  • This item available through special order only. Minimum order quantity is 50 pieces
We'll send you an email when Tang Band W5-2053 5" RBM Flat Panel Subwoofer 4 Ohm is back in stock or available for preorder.
Tang Band designed their revolutionary RBM (Real Balanced Mode) flat subwoofers for ultra-linear operation, while remaining as thin as possible. The secret to their low distortion performance is in the patented symmetrical suspension system.
While most subwoofers rely upon a spider/surround combination to keep the cone travel linear, Tang Band has developed a new injection molding process that incorporates front and rear cones, as well as dual opposed surrounds.
Similar to an isobaric subwoofer alignment, the two cones work together to modulate a single column of air, reducing non-linear harmonic distortion. The added mass of the rear cone/surround assembly also reduces free air resonance.
Tang Band's W5-2053 5" RBM mini subwoofer features extensive venting on the rear cone, voice coil former, and back plate to keep the large, overhung, neodymium-powered voice coil cool. A bumped back plate allows for momentary moments of over-excursion without damage. Additionally, it offers low distortion frequency response that reaches down to 35 Hz.
BrandTang Band
ModelW5-2053
Part Number264-953
UPC848864015071
Weight5.9
Nominal Diameter5"
Bolt Circle Diameter6.625
Power Handling (RMS)40 Watts
Power Handling (MAX)80 Watts
Frequency Response35 to 800Hz
Sensitivity80dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.19mH
Mechanical Q (Qms)4.64
Electromagnetic Q (Qes)0.36
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)0.14ft³
BL Product (BL)9.31T·m
Diaphragm Mass Inc. Airload (Mms)39.92g
Maximum Linear Excursion (Xmax)8mm
Surface Area of Cone (Sd)75cm²
Cone MaterialPoly Composite
Overall Outside Diameter5.9375" across the flats, 7.125"
Baffle Cutout Diameter5.09"
Depth3.62"
Sealed Volume0.08ft³
Sealed F389.1Hz
Vented Volume0.15ft³
Vented F334.6Hz
