  • Tang Band W4-2356 4" Off-Axis Poly Cone Full-Range
CLEARANCE Tang Band W4-2356 4" Off-Axis Poly Cone Full-Range
Tang BandPart # 264-982
Model: W4-2356
The Tang Band W4-2356 4" Off-Axis Poly Cone Full-Range driver is a very unique, one-of-a-kind speaker that utilizes an off-center voice coil and asymmetric cone profile to help reduce diffraction effects that are common with smaller speakers.
  • Unique off-center voice coil helps decrease beaming and diffraction effects
  • Asymmetric polypropylene cone and rubber surround
  • Large neodymium ring magnet and underhung coil for increased efficiency
CLEARANCE $89.00
MSRP: $205.99
Save $116.99 (57%)
3 In Stock
We'll send you an email when Tang Band W4-2356 4" Off-Axis Poly Cone Full-Range is back in stock or available for preorder.
Order in the next 10 hr 55 min to ship today. Details
The Tang Band W4-2356 4" Off-Axis Poly Cone Full-Range driver is a very unique, one-of-a-kind speaker that utilizes an off-center voice coil and asymmetric cone profile to help reduce diffraction effects that are common with smaller speakers and narrow baffles.
The The Tang Band W4-2356 utilizes an injection molded polypropylene cone, solid aluminum phase plug which helps with heat dissipation and diffusion. Rounding out the design is a patented two-piece offset plastic composite frame and large, underhung neo ring motor for increased sensitivity and decreased distortion.
BrandTang Band
ModelW4-2356
Part Number264-982
UPC848864074832
Weight1.95
Nominal Diameter4"
Bolt Circle Diameter4.52
Power Handling (RMS)25 Watts
Power Handling (MAX)50 Watts
Frequency Response70 to 20,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter25.4"
Resonant Frequency (Fs)70Hz
DC Resistance (Re)6.8Ω
Voice Coil Inductance (Le)0.06mH
Mechanical Q (Qms)1.83
Electromagnetic Q (Qes)0.59
Total Q (Qts)0.45
Compliance Equivalent Volume (Vas)0.14ft³
BL Product (BL)4.94T·m
Diaphragm Mass Inc. Airload (Mms)4.99g
Surface Area of Cone (Sd)50cm²
Cone MaterialPoly
Surround MaterialSantoprene®
Magnet MaterialNeodymium
Overall Outside Diameter4.94"
Depth2.57"
