  • Tang Band W1-2396S Extremely Slim 1" Full-Range 4 Ohm
NEW Tang Band W1-2396S Extremely Slim 1" Full-Range 4 Ohm
Tang BandPart # 264-818
Model: W1-2396S
The Tang Band W1-2396S is an extremely slim 1″ full-range driver designed for applications where space is limited but wide bandwidth is still required. Its lightweight moving system and compact neodymium motor allow it to reproduce a broad range of frequencies from a very small driver, making it suitable for compact audio devices and miniature speaker systems.
  • Extremely slim 1″ full-range driver supports audio output in very space-limited designs
  • Polypropylene cone improves stiffness for clearer sound reproduction
  • Santoprene surround helps maintain controlled cone motion for smoother response
  • Neodymium magnet motor provides strong magnetic drive in a compact structure
  • Frequency response 180–20,000 Hz covers a wide bandwidth for small full-range systems
  • Ferrofluid-enhanced voice coil improves thermal stability and reliability during operation
NEW $27.90
We'll send you an email when Tang Band W1-2396S Extremely Slim 1" Full-Range 4 Ohm is back in stock or available for preorder.
Order in the next 2 hr 51 min to ship today. Details
BrandTang Band
ModelW1-2396S
Part Number264-818
UPC848864082387
Weight0.1
Nominal Diameter1"
Power Handling (RMS)3 Watts
Power Handling (MAX)6 Watts
Frequency Response180 to 20,000Hz
Sensitivity81dB 2.83V/1m
Voice Coil Diameter0.76"
Resonant Frequency (Fs)180Hz
Mechanical Q (Qms)2.21
Electromagnetic Q (Qes)0.8
Total Q (Qts)0.59
Compliance Equivalent Volume (Vas)0.004ft³
BL Product (BL)2.13T·m
Diaphragm Mass Inc. Airload (Mms)0.9g
Maximum Linear Excursion (Xmax)1.1mm
Surround MaterialSantoprene®
Magnet MaterialNeodymium
Overall Outside Diameter1.81"
Depth0.469"
