Tang Band 25-2234SE 1" Hi-Resolution 40k Aluminum/Magnesium Dome Neo Tweeter Stainless Grill 4 Ohm
- Delivers flat response from 1,000 Hz up to 40,000 Hz to reproduce even the finest details
- Decorative stainless steel grill protects the fragile dome
- Compact 1.88" square faceplate for use in even the smallest systems
- Aluminum/Magnesium dome has excellent damping properties
- This item available through special order only. Minimum order quantity is 50 pieces
We'll send you an email when Tang Band 25-2234SE 1" Hi-Resolution 40k Aluminum/Magnesium Dome Neo Tweeter Stainless Grill 4 Ohm is back in stock or available for preorder.
